Modeling a Sliding Constraint
Posted 2013/01/31 5:10 JST Structural Mechanics Version 4.3a 2 Replies
I am trying to model a sliding constraint, basically a pin in a hole.
To try to understand how best to apply the contraints I created a simple model of a tube and rod. The tube and rode are both 1 m long, the rod is inserted .1m into the tube the Tube ID and Rod OD are the same. I fix the free ends of the tube and rod. Then I run an Eigenfrequency study on the assembly.
If the geometry is a union (or assembly with continuity at the sliding interface), the first mode of the two parts is as expected a single wave bow of the system.
If the geometry is an assembly with a roller pair at the sliding interface, the model behaves as if the roller is fixed in space. i.e. the area where the rod is in the tube does not deflect. Rather the first couple modes are of the rod bowing then the tube bowing.
So how does one model a sliding contraint that can move with the surrounding geometry?
I have attached a version 4.3a model that I have been querying. Switch between the continuity 3 and Roller 1 constraint to see the differences as descriped above.
2 Replies Last Post 2013/02/01 7:10 JST
