Change x-axis units in table plot
Hi all,
I have a 3d model of diffusion from a source and am calculating surface integrals of flux over particular features in my geometry. This outputs a table of total flux vs. time point which can then be plotted in a 1d plot group table plot. However, the default output of this is with respect to seconds as used in the time dependent solver and I cannot figure out any way to change the x-axis units to something else for display. When my changes of interest occur on the order of many hours, it is inconvenient to look at things in seconds. Thanks!
2 Replies Last Post 2013/01/31 14:53 JST
Posted: 1 decade ago 2013/01/31 14:51 JST
unfortunately it seems that the time as "X" axis is blocked in seconds, several of us has suggested to Support that this might be improved, it seems to be less trivial than that, for some internal reason, but OK, if we are many to ask it might arrive, so pls send the suggestion to "support"
Hi unfortunately it seems that the time as "X" axis is blocked in seconds, several of us has suggested to Support that this might be improved, it seems to be less trivial than that, for some internal reason, but OK, if we are many to ask it might arrive, so pls send the suggestion to "support" -- Good luck Ivar
Posted: 1 decade ago 2013/01/31 14:53 JST
Great thanks Ivar! For now I will export my table data and plot in another program, but would be nice to have this ability within COMSOL. I will submit this suggestion.
