2013/02/05 18:43 JST
I added the electric currents (ec) physics to my problem. I do the piezoelectric study first and then the electric currents. I made the piezoelectric material a current source, but still no current is flowing...
What am I missing?
What am I missing?
2013/02/05 19:28 JST
but normally PZT solves already for V arnt you doubling up your dependent variables ?
Normally you will only get current flow if you have a closed circuit with non zero conductivity, so I suspect that you have missed something in your model build-up
2013/02/05 19:55 JST
I use the solved V, from PZT, for the second study (ec).
The PZT model doesn't use the conductivity as part of the model?
2013/02/05 21:53 JST
that's it, because PZD solves for _u_ and V, there is nothing more by adding in EC and solving again for V2. So normally you can get everything via PZD physics
If you have defined a GND and a Terminal You should get a Voltage out, for a given impedance you have the bulk current too, and the complex impedance, and voltage gives you indications on phase lag
2013/02/05 22:34 JST
Thanks, think I am getting to where I want to be!
2013/07/24 22:07 JST
Hi Stanley,
How did you find the current / impedance?
Naveet
Hi Stanley,
Naveet
2013/07/24 22:14 JST
Hi Naveet,
The solution I came up with is using the AC/DC module, not sure if you have it?
I add the second physics (the AC/DC). In the piezoelectric physics I specify the top end of my piezoelectric device (where the maximum voltage is) as a Terminal.
In the AC/DC module I can then use that Terminal as a voltage source, close the loop with a resistor and a current is measured.
The problem with this solution is that the current is a constant. There is no variation with resistance within the device.
Please let me know if this helps and if you maybe find a better solution.
Hi Naveet,
