Heat Transfer, Joule Heating, 1D Plot Global
Posted 2013/02/06 5:00 GMT-5 Heat Transfer & Phase Change Version 4.3a 1 Reply
I have a following problem.
I use the module “Joule Heating”, and I want to calculate a resistance in the temperature dependence (“Time Dependent Study”).
How can I display the global temperature dependence of the time in a 1D Plot Global. I also Use the condition “Heat Flux” (qo = h (Text-T)) and also want to illustrate Text-T over the time.
An attempt was made to declare the global variable mod1.T under another name in
“Definition / Variable” to, but it does not work.
The error is as follows:
-Variable: mod1: T
-Global scope:
Variable: mode1.T_test
-Defined as: mod1.T
-Expression: mod1.T_test
-Plot: global1 (Global)
-Variable: mod1: T
-Global scope:
-Defined as: mod1.T
1 Reply Last Post 2013/02/06 5:40 GMT-5
