Batch Sweep
Geolxc 浙江大学建筑工程学院/数字孪生
When I'm applying the batch scanning in COMSOL, I need to add quite a large number of model parameters (more than 100 different parameters). Due to the "Add parameters to file name" option in the COMSOL batch processing settings, this will cause the naming of the model files for parallel computing to exceed the maximum naming length allowed by the computer (generally, it's not allowed to exceed 255 characters). As a result, the parallel external process cannot be executed (the main reason being that the file name exceeds the limit). I'm wondering if there are any ways to avoid this problem or if the technical support team could offer some assistance. Thank you very much!
2 Replies Last Post 2024/12/11 23:30 GMT-5
Jeff Hiller COMSOL Employee
Posted: 12 months ago 2024/12/11 8:19 GMT-5
To request support from COMSOL's technical support team, please use the support portal (www.comsol.com/support).
Jeff Hiller
Hello, To request support from COMSOL's technical support team, please use the support portal (www.comsol.com/support). Best regards, Jeff
Posted: 12 months ago 2024/12/11 23:30 GMT-5
Thank you for your reply. I've already submitted this problem to the technical support.
>Hello, > >To request support from COMSOL's technical support team, please use the support portal (www.comsol.com/support). > >Best regards, > >Jeff Thank you for your reply. I've already submitted this problem to the technical support.
