2 years ago
2024/12/29 18:22 GMT-5
Your message is clear and professional! Here's a slightly refined version to enhance readability and flow:
The default directions of piezoelectric material properties in the built-in COMSOL material library (in 3D space) are as follows:
1 → x-axis
2 → y-axis
3 → z-axis
Typically, the poling direction aligns with the z-axis.
When working on a 2D model, you need to specify the desired plane using one of the six available coordinate systems: XY, YZ, ZX, YX, ZY, or XZ.
I recommend using the default XZ coordinate system, which aligns the x and y axes in the 2D model with the original x and z directions in the 3D coordinate system of the material properties.
Please note that for 2D structural modeling, you must choose between the plane-stress or plane-strain assumptions. Additionally, please be cautious about removing elements of the coupling matrix (d) for reduction purposes, as this may lead to errors in your analysis.
Milad
1 → x-axis
2 → y-axis
3 → z-axis
Milad
2 years ago
2024/12/31 16:47 GMT-5
How do I specify the desired plane? What significance is the ordering of the 6 planes systems?
The motivation for removing elements of the coupling matrix is to make the results simpler to understand. My immediate goal is to demonstrate a 1D "piezo spring" by two methods.
- A 2 dimensional simulation with variation in only 1 dimension. I wish to create an artificial material properties such that the piezo coupling is simplest: a single non-zero element in the coupling matrix. I expect the eigenmodes to be simple enough also. The lowest order mode will be half a wavelength across the dimension of variation, and there will be harmonics above that.
- A 1D dimensional simulation using Coefficient Form PDE. COMSOL does not support piezo multiphysics in 1D. I should get the same results as the 2D simulation described already. This model is attached. I have the PDEs setup but I am still working on how to understand the boundary conditions, studies, and results. I don't understand how to constrain the left side of the interval, while the rest of the interval is free to shrink and expand. I want to plot the time domain solution of the some points along the interval.
For both simulations, I want to back out the ideal material electro-mechanical coupling coefficient via measurement, which should be a function of the material properties. If they match, I have confidence in more realistic and complicated resonator design simulation results.
1. A 2 dimensional simulation with variation in only 1 dimension. I wish to create an artificial material properties such that the piezo coupling is simplest: a single non-zero element in the coupling matrix. I expect the eigenmodes to be simple enough also. The lowest order mode will be half a wavelength across the dimension of variation, and there will be harmonics above that.
2. A 1D dimensional simulation using Coefficient Form PDE. COMSOL does not support piezo multiphysics in 1D. I should get the same results as the 2D simulation described already. This model is attached. I have the PDEs setup but I am still working on how to understand the boundary conditions, studies, and results. I don't understand how to constrain the left side of the interval, while the rest of the interval is free to shrink and expand. I want to plot the time domain solution of the some points along the interval.
