coil winding direction
How do I determine the direction of the magnetic induction in multi turn coils.
Thank.
1 Reply Last Post 2013/02/14 3:32 JST
Posted: 1 decade ago 2013/02/14 3:32 JST
in 2D via the sign, in 3D via the loop sub node (right click multiturn/signle turn coil node and add corresponding sub-node "Edge reference")
it's described in the 4.3a ACDC user manual, under "Coil Domains" section probably in earleier versions too
Hi in 2D via the sign, in 3D via the loop sub node (right click multiturn/signle turn coil node and add corresponding sub-node "Edge reference") it's described in the 4.3a ACDC user manual, under "Coil Domains" section probably in earleier versions too -- Good luck Ivar
