safe to manually delete?
hey there
I uninstalled all the old version of COMSOL over control panel but I still found lotsa old directories
C:\Users\xxx\.comsol\v(n)
is it safe to delete all of the old ones manually?
Appreciate your advise. Thanks in advance!
regards
Liwah
1 Reply Last Post 2013/02/19 0:07 JST
Posted: 1 decade ago 2013/02/19 0:07 JST
in the ...user/xxx/.comsol you have the usual private settings, as well as by default your private material DB and sometimes a lot of tmp files or backup files.
If you hae saved your material datbase file, if of interest, I would say 99.9% of the content therein can be deleted without thoughts. At most, next time you install COMSOL, you need to redefine your private specific settings (views etc)
Hi in the ...user/xxx/.comsol you have the usual private settings, as well as by default your private material DB and sometimes a lot of tmp files or backup files. If you hae saved your material datbase file, if of interest, I would say 99.9% of the content therein can be deleted without thoughts. At most, next time you install COMSOL, you need to redefine your private specific settings (views etc) -- Good luck Ivar
