2013/02/22 21:26 JST
are you sure you selected "3D" or "2D" when starting your model ?
2013/02/22 23:58 JST
Yes, of course I'm sure I selected 3D . I don't understand why the program gives this error :(
When I changed the electrical circuit node's parameters (for example resistor, external I vs U. parameters (i.e p:3 n is empty) etc. ) this time program gives an another error such as "The DAE is structurally inconsistent. Variables:2 Equations:1 Error in automatic sequence generation"
I appreciate you can give me some suggestion
Regards
Asli
Regards
Asli
2013/02/23 3:16 JST
it's rue CIRis 0D "physics" so it's therein, you need to have a logical circuit without tangling items, check again your id numers, and note these re different (not linked) to the Terminal number id's
2013/02/24 18:28 JST
Hello Mr. Ivar,
What are the means of the terminal numbers and id numbers? Can you give me an example? I can not found the solution :(
My elecrical circuit (cir) parameters are:
Groung node 1: Connected to node 0
Voltage Source: p:1 n:0
External I Vs. U 1 : p:2 n:1
Resistor 1 : p:0 n:2
External I Vs. U 2 : p:3 n:0
Resistor 2: p:0 n:3
Hello Mr. Ivar,
Resistor 2: p:0 n:3
2013/05/13 19:57 JST
I am having the exact same issue attempting to model an E-Core transformer. Has anyone found out what the problem was?
2013/07/03 2:14 JST
Were you using the time domain, as in the example model? I was also having this problem, and I discovered that switching from frequency domain to time domain fixed it.
2013/11/28 23:10 JST
Do you mean model in this site?
I had same problem.
First, I only solve with time dependent study.
It was solved. And then, I added coil calculation. It worked.
I had same problem.
9 years ago
2016/04/07 21:43 JST
hello,I have the same problem,but I find the solution method .Maybe you circuit source is wrong ,and you can change it.
