Plotting unmeshed/unused geometry into the results
MCT Chemical Engineering
Let's say I want to mesh only part of an entire geometry and run a laminar flow simulation in domains 1-3, but do not want to include domains 4-6 in the laminar flow simulation. Is there a way to add domains 4-6 into the final postprocessing results (i.e., plotting a 3D velocity contour slice with domains 1-6) after the laminar flow simulation ends?
Thanks.
1 Reply Last Post 2025/03/22 7:30 GMT-5
Posted: 2 years ago 2025/03/22 7:30 GMT-5
You can mesh all domains and have physics on 1-3 only. Then you will see the datalines of the "container" (if that is what 4-6 is), and you can put field variable colors or contours on 1-3, and some uniform color on 4-6 to show it also.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
