Unable to create mesh : Error Free Tetrahedral 1
Hi everybody,
I am having this error when I try to mesh a 3D structure :
The following features have problems :
Features : Free Tetrahedral 1
I don't find a way to have more information about this error.
My geometry is really complex, with many points/edges. I cannot make it simpler.
I still have the same error when I change the element size to be 'Extremely coarse'.
Does someone have an idea to fix this error ?
Thanks.
4 Replies Last Post 2014/06/09 15:19 JST
Posted: 1 decade ago 2013/02/26 16:03 JST
there is no "one solution" for fixing a topology issue when meshing ;)
But you should get some indications where (coordinates) or which boundary you have the problem.
Then think of how you might cut your domain in 2 or more such to ease the meshing, and mesh by "shunks" or pre-mesh some boundaries manually, some edges ...
Hi there is no "one solution" for fixing a topology issue when meshing ;) But you should get some indications where (coordinates) or which boundary you have the problem. Then think of how you might cut your domain in 2 or more such to ease the meshing, and mesh by "shunks" or pre-mesh some boundaries manually, some edges ... -- Good luck Ivar
Posted: 1 decade ago 2013/04/13 3:43 JST
I solved my problem! I had the same error. I am simulating a nano antenna which is not very complicated, but is very small in some parts. I had several errors in mesh part and defined meshes for the edges, but it did not helped. So I defined different sections for specific points and I do not have any errors now.
Zahra
Hi, I solved my problem! I had the same error. I am simulating a nano antenna which is not very complicated, but is very small in some parts. I had several errors in mesh part and defined meshes for the edges, but it did not helped. So I defined different sections for specific points and I do not have any errors now. Regards, Zahra
Posted: 1 decade ago 2014/06/07 8:45 JST
I am working on very simple cylindrical geometry. I am using heat transfer through solids and surface to ambient radiation. I made a central line in the cylinder, as i need temperature distribution along this line. When I go for finer meshing. I am getting 'A problem arose from when building mesh feature 'free tetrahedral 1a {ftet1}''. Please help !
Posted: 1 decade ago 2014/06/09 15:19 JST
Do you mean that you drew a line under Geometry node? In order to find, say, a temperature distubution along a line you do not need to draw it, but define a 3D Cut Line under Results --> Data Sets node.
Lasse
Do you mean that you drew a line under Geometry node? In order to find, say, a temperature distubution along a line you do not need to draw it, but define a 3D Cut Line under Results --> Data Sets node. Lasse
