Periodic Boundary Condition in General Form PDE -- No Solution for very Simple Equation
Posted 2025/06/23 10:30 GMT-5 Equation-Based Modeling Version 6.0 1 Reply
Dear COMSOL community,
I have a lack in understanding solving PDE with PBC, which I can break down to a very simple example, i.e. finding a solution for .
The height and width of the 2D simulation domain is
, and at the top and bottom a Dirichlet BC (
) should be applied, while at the left and right site a periodic BC should be applied.
Integrating above equation twice, is given as
and from the Dirichlet BC we get
and from the periodic BC
However, when implementing this in the COMSOL general form PDE interface and solving using a Stationary Solver, I do not get the result but an error "Failed to find a solution.
The relative error (0.0092) is greater than the relative tolerance.", even not when I use the calculated solution as initial values. However, when replacing the periodic BC at the left and right Interface with a Dirichlet BC , I get the expected result.
Therefore, I have two questions:
- Why don't I get any result when using periodic BC at the left and right interface?
- Why does the periodic BC not overwrite the default Zero Flux 1 BC, but contribute to it? I also implemented what is suggested here, which then overwrites the Zero Flux 1 BC, but I get the same error as using the implemented Periodic Condition.
Attached is a file of the simulation.
Thank you in advance!
