Robert Koslover
Certified Consultant
2 decades ago
2010/03/08 10:28 JST
Yes, this sounds like a meshing problem.
Any chance that you are modeling an H-plane T? If so, depending on the geometry of your inserted parts (the glass and TiO2) you may be able to run the simulation in 2D. If so, you can use a much finer mesh.
Alternatively, you need to get more skilled with meshing. Most importantly, you can mesh your problem one subdomain at a time, rather than all at once. Go to Mesh --> Free Mesh Parameters and choose the subdomain tab. Set the max element size for each subdomain appropriately. On the advanced tab, you can choose different scale factors in x,y, and z dimensions. Again, choose thoughtfully and do some experimenting with those settings, going back to the subdomain tab and choosing Mesh Selected, not just Remesh, so you can mesh one subdomain at a time. You may have to clear the whole mesh (choose File --> Reset Model) and start meshing over again, in order to fix any mistakes.
Good luck.
Good luck.
Robert Koslover
2 decades ago
2010/03/08 10:31 JST
I should also have asked: "Why are you "changing the conductivity of the TiO2 from 1e-9 to 1e9" ?? Either you know it's conductivity or you don't, right? So that seems strange to me.
2 decades ago
2010/03/08 23:31 JST
Thanks for the information, I will try to do that and hope it will solve my problem.
The explanation to your question.
I am changing the conductivity to know what is the limit value of (low) dark conductivity where the reflectance is independent of conductivity. My calculation are based on the understanding that at low conductivity , the reflectance is independent of the conductivity. I am expecting that after the limit value of the conductivity the reflectance will start to change.
[QUOTE]
[/QUOTE]
