problem with port boundary condition
I am trying to simulate a coupler so I need to set a port as inport and I have to select "wave excitation at this port " check box but it's inactive.
How can I activate it?
sara
3 Replies Last Post 2013/03/09 8:37 JST
Posted: 1 decade ago 2013/03/08 5:42 JST
if yI remember well there are some limitations on the boundaries where these can apply (eiteh internal or external but how it was back in 3.5 times is getting to vague for me, try to check the doc, and verify for which type of boundary it applies
Hi if yI remember well there are some limitations on the boundaries where these can apply (eiteh internal or external but how it was back in 3.5 times is getting to vague for me, try to check the doc, and verify for which type of boundary it applies -- Good luck Ivar
Posted: 1 decade ago 2013/03/09 4:03 JST
Hi Ivar,
Thanks, the problem was that it was defined as an inner boundary,I apply the sourc (the defult of comsol) ,but there is no wave propagation so S-parameter does not return any diagram, what should I do?
Best Regards,
Sara
Hi Ivar, Thanks, the problem was that it was defined as an inner boundary,I apply the sourc (the defult of comsol) ,but there is no wave propagation so S-parameter does not return any diagram, what should I do? Best Regards, Sara
Posted: 1 decade ago 2013/03/09 8:37 JST
The simplest rule here is, "Don't try to define an internal boundary as a port." I have found that it is generally possible to configure the geometry of just about any problem so that ports can always be placed on only external boundaries.
