Parameters in file name
Hello all,
I am in a situation where I need to work with 40 or so parameters, and as a result when I export my results from a parametric sweep (with parameters appended to the file name) the file becomes too large to save. Is there a way to select which parameters are appended to the file name? On the flip side, is there a way to define "parameter sets" in which 1 parameter defines the others?
Aaron Shifman
6 Replies Last Post 2014/10/01 20:50 JST
Posted: 1 decade ago 2013/03/25 15:30 JST
there was a way back in 3.5 time, to get each parameter into a new file but then you can only read them out one at the time. But I have newer tried this in v4. Have you checked the Export tab help and doc ?
then you have batch mode and matlab for sure
Hi there was a way back in 3.5 time, to get each parameter into a new file but then you can only read them out one at the time. But I have newer tried this in v4. Have you checked the Export tab help and doc ? then you have batch mode and matlab for sure -- Good luck Ivar
Posted: 1 decade ago 2013/03/26 1:41 JST
Yes. Create a table where first column defines the 1st parameter and the rest of columns with "parameters sets" corresponding to the first parameter. Then define the interpolation function in COMSOL and load the file with the table of parameters. Choose number of parameters - one. Then for each of the parameters in the "parameter set" define the separate function.
[QUOTE] On the flip side, is there a way to define "parameter sets" in which 1 parameter defines the others? [/QUOTE] Yes. Create a table where first column defines the 1st parameter and the rest of columns with "parameters sets" corresponding to the first parameter. Then define the interpolation function in COMSOL and load the file with the table of parameters. Choose number of parameters - one. Then for each of the parameters in the "parameter set" define the separate function.
Posted: 1 decade ago 2013/03/26 22:58 JST
Hi Alexander,
That sounds like it would work well, except that it appears that I can only have 3 arguments for these parameters, I have 11. How do I get around that?
Aaron Shifman
Hi Alexander, That sounds like it would work well, except that it appears that I can only have 3 arguments for these parameters, I have 11. How do I get around that? Thanks, Aaron Shifman
Posted: 1 decade ago 2013/03/28 10:12 JST
Hi Ivar,
The I wen't through the documentation for the export tab, but I didn't see anything related to which parameters are listed in the file name. Is there no way to do a "custom" file name, or somehow reference the parameter value when I define the export file?
Aaron Shifman
Hi Ivar, The I wen't through the documentation for the export tab, but I didn't see anything related to which parameters are listed in the file name. Is there no way to do a "custom" file name, or somehow reference the parameter value when I define the export file? Thanks, Aaron Shifman
Posted: 1 decade ago 2014/10/01 13:48 JST
Hi Ivar,
Do you know how to export data through batch mode using command line without GUI?
What should I write in command line?
Weijia
Hi Ivar, Do you know how to export data through batch mode using command line without GUI? What should I write in command line? Weijia
Posted: 1 decade ago 2014/10/01 20:50 JST
Hey,
Yeah, I also want to know how to export data so please notify me if you find a way. :)
Ivelin
Hey, Yeah, I also want to know how to export data so please notify me if you find a way. :) Ivelin
