How to calculate the transmission
Posted 2013/03/25 23:22 JST RF & Microwave Engineering Version 4.4 7 Replies
I have a question about how to calculate the trasmission through the nanostructure.
For example, in the "Optical Scattering Off of a Gold Nanosphere" tutorial, we tell comsol to solve for "scattered field" and also use "far field domain".
If I want to know how much light is transmitted in this model, how can I get it?
My idea for solving this problem is to integrate "emw.normEfar^2" in the far-field boundary, but it seems to be a wrong strategy for getting the transmission(unit : %).
Could you let me know how I can calculate the transmission when I use "scattered field"?
I think so, but what I want to do in the end is to calculate the transmission of 2D diffraction grating.
In case of 2D diffraction, it's highly complicated to think of all ports, especially the diagonal diffraction mode.
Comsol support suggests me to use the scattered field and PMLs, instead of ports.
However, when it comes down to it, I cannot find the way to get the transmission.
This is the plot.
Yutaro
For 2D gratings you have the same number of ports as for 1D: just two ports. You will need to setup more periodic BCs as well as excitation at the "in" port which is still easier than setting up the background field. And at the end, the transmission and reflection are automatically calculated for you.
Another strong argument for periodic BC is that you will need to simulate only one period of the grating. In the case of PMLs, you will need to include many more unit cells in order to achieve the same accuracy.
Could you elaborate a little bit more?
"For 2D gratings you have the same number of ports as for 1D: just two ports. You will need to setup more periodic BCs as well as excitation at the "in" port"
In the "plasmonic wire grating" tutorial, we have to prepare 6 ports (including 1 excitation port) because there are 0, ±1 order diffractions.
If we want to simulate 2D diffraction grating, for example 2D nanowire square mesh, I think we have (0, 0), (0, ±1), (±1, 0) order diffraction, and what's more, depending on the wavelength and diffraction period, we have even (±1, ±1) order diffraction, which is the diagonal direction.
Could you let me know why we need only two ports and the meaning of "more excitation ports"?
"In the case of PMLs, you will need to include many more unit cells in order to achieve the same accuracy."
In the "plasmonic wire grating" tutorial, we put ports on top and bottom and put periodic BCs on sides.
I replace these ports with PMLs (so PMLs on top and bottom and periodic BCs on sides). I've tried only normal incident wave, but the 2D plot (electric field norm) from the PMLs case looks quite similar to the one I got from the "port" case. Is it difficult or inaccurate to get the transmission from this result?
Sincerely,
Yutaro
At the end, it all gets down to correctly writing one k-vector for each diffraction order (which is unfortunately not trivial). I suggest starting from simpler cases such as normal incidence, etc and testing transmission through a film as there is analytical solution to it.
2. I have never tested "scattered field" formulation together with periodic BC. I see several ways in which it can fail depending on the particular implementation. If it works for you, let us know!
For "scattered field", I always use 6 PMLs.
I had made a 2D grating structures in 3D modeling Wizard of Comsol 4.4 version, While I am putting Diffraction orders( m=0, n=0 ; m=-1, m=-1, n=0 ; m=+1, n=0) with "port reference points" as diagonally opposite end of Unit square cell with periodic boundary conditions on all four sides( by doing copay face). Unfortunately it gives me zero electric filed while i am running., If I run the same model without diffraction order it gives the result but only from one order diffraction (normal reflection) . Since I need to calculate reflection from at least two orders (0 th order and 1 st order) I have to include those diffraction orders to my model
Can you help me in this regard?
can any one tell me how to put diffraction orders (with proper port reference points)in 2d grating on 3D model?
Also How can i implement PML layer over the port, since if i add pml layer on the top of port, selecting port reference point is declined by default. I follow the pyramidal absorption model for making the infinite array of my 2d Grating nano structures( there a PML layer added over the port)
the plasmonic wire grating model available in Comsol library is just a 2D model , so we can't able to follow the same thing in here in our model.
I used this blog for making port reference points and putting periodic ports
www.comsol.co.in/blogs/modeling-electromagnetic-waves-periodic-structures/
Please anybody help me in this regard..
Thank you
Aneesh M Joseph
www.comsol.co.in/blogs/modelin...tic-waves-periodic-structures/
Thank you
Aneesh M Joseph
Suggested Content
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling? - BLOG Using Numeric TEM Ports in Your Modeling Processes
- KNOWLEDGE BASE COMSOL Installation Companion
- FORUM calculate the transmission
- KNOWLEDGE BASE Performing a Mesh Refinement Study
