Physics for a elastomeric vibration isolator.
Posted 2013/03/28 7:02 GMT-4 Acoustics & Vibrations, Modeling Tools & Definitions, Parameters, Variables, & Functions, Structural Mechanics Version 4.3 4 Replies
Good morning.
I'm almost finished with my model.
The model consists in : 1 - Base. ( Base )
2 - Elastomeric Rubber. ( Borracha)
3 - Lid. (Tampa)
4 - Screw Hole.( Parafuso )
The Screw Hole receive the vibration then pushes down ( or up ) the lid. The lid then compresses the rubber part isolating the vibration.
I have so far modeled each part on it's own, including they're meshes. But when I put them on the same model , using ' Insert Sequence from File ' I can't get it to work .
I tried using 'Boundary Conditions' such as - Fixed Constraint; - Rigid Connector ; Boundary Load ; Etc...
What I'm trying to make it work first is that when the Screw Hole goes up and down , it will make the Rubber move as well. But sometimes the Rubber part is deformed INSIDE the Screw Hole.
I'd like to ask for some help here so I can make my model work properly .
Thank you very much .
Victor Soares
3 - Lid. (Tampa)
Victor Soares
4 Replies Last Post 2013/04/03 10:32 GMT-4
