Josh Thomas
Certified Consultant
2013/04/02 9:40 GMT-4
Khalid,
Have you considered defining parametric curves? Right-click on Geometry 1 and select Parametric Curve. Then, in the edit field you can define expressions for your x and y coordinates based on a parameter s. You will need to know/develop the mathematical equation for the spiral edges in this case. Then, you can use Bezier Polygon line segments to connect the ends. And, then use a Conver to Solid operation to convert the edges into a solid body.
There may be a simpler way to do this, but this is the first that comes to mind.
Josh Thomas
AltaSim Technologies
Khalid,
Josh Thomas
Edgar J. Kaiser
2013/04/02 9:53 GMT-4
Khalid,
is this similar to what you need?
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Khalid,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
2013/04/03 4:58 GMT-4
Khalid,
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Yes its quite the same, except the number of turns are higher than this.
Regards
Khalid Hameed
[QUOTE]
Khalid,
Cheers
Edgar
Edgar J. Kaiser
[/QUOTE]
Regards
Khalid Hameed
2013/04/03 5:25 GMT-4
Khalid,
Josh Thomas
I have tried using archimedes spiral but that is different in geometry, in addition the equation given in most places are for 2D. I am trying to work on equation to get the geometry
[QUOTE]
Khalid,
Josh Thomas
[/QUOTE]
9 years ago
2016/06/07 10:05 GMT-4
Wow,it dose help for me , thank you for your sharing. Best wishes!
