Plasticity - Cyclic Hardening
Posted 2013/04/04 1:54 JST Materials, Structural Mechanics Version 4.3a 2 Replies
Hi all,
I am modelling a process where a steel plate is subject to cyclic forces that cause plastic deformation.
As the process is cyclic I am inclined to use the kinematic hardening option - I am however slightly confused by the description in the COMSOL documentation.
Am i correct in thinking that the kinematic hardening model uses Pragers rule and is therefore a bi-linear model?
Within the isotropic hardening module there is an option to input a user defined hardening function. Clearly this can be non linear however I presume this can never recreate the kinematic model i.e moving the yield surface as opposed to extending it?
Does anyone have any experience implementing a kinematic hardening model in comsol other than the default?
Also as an aside, I am running a simulation of cyclic loading. Currently I have the load described as a variable of time and am running a time dependent solution over a number of cycles. Is there a more efficient way to do this? possibly using the stationary solver?
Any help would be appreciated,
2 Replies Last Post 2013/06/06 0:06 JST
