2 decades ago
2010/03/04 4:05 GMT-5
have you tried to type log10(T) instead of just "T" for your variable (here T=temperature), but this applies to any positive variable name
2 decades ago
2010/03/04 4:28 GMT-5
Thanks Ivar.
I was under the impression that there is a shortcut function (or icon) to do this. Anyway, your method is pretty easy as well.
Thanks Ivar.
2014/12/17 9:41 GMT-5
Is there a way to make a log scale for quantities that are both positive and negative. For example, an electric or magnetic field whose direction varies as a function of position? I am particularly interested in 3D or multi-slice plots and I would like to see not only the magnitude but also the direction on the same plot as a function of position.
9 years ago
2016/08/31 15:01 GMT-4
I am working on a heat transfer and laminar flow problem, I want to get the plot in log scale for the flow. I put log10 before the flow rate in the parametric sweep, where I am using range. So, the range is range(-4.778064400171995,4/9,-0.7780644001719947).
Which is negative and it gave me error.
In matlab I used logspace(0,4,100)*0.06 command , which gives me, ranges (0,06 to 600) in logarithmic scale. I want to do the same in comsol
Would you please help me?
