Moving mesh example
Posted 2013/04/18 11:20 GMT-4 Mesh Version 4.4 8 Replies
Is there any example of using moving mesh with a pdf guideline?
I need to model a moving magnet next to a coil and calculate the induced voltage!
I am still working on your example to understand what it is trying to do. A quick question: in the prescribed deformation, domains 5 and 6 are assigned to have a prescribed mesh deformation in z direction. NA later on in prescribed mesh displacement 4 we assign the one of the boundaries of domains 5 and 6 to have the same prescribed z displacement, why?
Sure, I will share it with you and I made this working. BUt first I have to remove soem of the parts which will be our design. So If I forget to do this with in the next days, remind me.
Ehsan
When my model has a small work distance (i.e., we need less remeshing times), the moving mesh can work very well, but when it comes to a big model. It doesn't work..
So i really want to know if I have a wrong seeting?
Plz be kind share me your example.
Thank you so much.
Feifan
I ma doing moving mesh of food due to heat and mass transfer.
Do you have any moving mesh example with PDF guideline.
Thank you in advance.
King regards,
Mohammad Joardder
Can you send me the example of the moving mesh model? I am working on a similar motion described in the thread and would like something to follow.
Thank you
Suggested Content
- FORUM Moving mesh example
- KNOWLEDGE BASE Avoiding Negative Concentrations
- BLOG Part 1: How to Model a Linear Electromagnetic Plunger
- KNOWLEDGE BASE COMSOL and Multithreading
- BLOG Modeling Free Surfaces in COMSOL Multiphysics® with Moving Mesh
