Livelink for Matlab
I would like to create a simple model using API in Matlab. When I type the command "shell.feature.create('fc1', 'FixedConstraint') ", errors "Unkonwn feature ID#FixedConstraint" exsit.
I have called for help from doucumention but found nothing. So what the "known feature ID" about the "FixedConstraint".
Many thanks for any help!
3 Replies Last Post 2013/04/20 5:29 GMT-4
Posted: 1 decade ago 2013/04/19 22:15 GMT-4
I loaded a model from model library of structural mechanic and type the command 'mphnavigator' and I find the type name of fixed constraint.
Posted: 1 decade ago 2013/04/20 2:08 GMT-4
Hi!
to learn these things, link the syntax, you better open Comsol GUI, define few simple features in a new model and export a .m file. There you'll read the correct syntax to apply your constraint.
Hope it helps,
Mattia
Hi! to learn these things, link the syntax, you better open Comsol GUI, define few simple features in a new model and export a .m file. There you'll read the correct syntax to apply your constraint. Hope it helps, Mattia
Posted: 1 decade ago 2013/04/20 5:29 GMT-4
Thank you Mattia, I saved a model as .m file, it's a straightforward way to learn syntax.
