State Space Export
Hi ,
i have build a simple cantilever beam model using time depented model.
after defining the points of forces and parameters, i want to export the model to matlb (State Space Matrices) so i could "play" with the paramters and their location.
for example applying force at the tip = 100sin(theta(t)) and applying more forces to restrain the system.
i have searched the forum and found the mphstate function but i wasn't able to use it.
would like to get some help and tipps :)
(sorry for my poor english)
Regards, Eyal
7 Replies Last Post 2013/09/13 21:45 JST
Posted: 1 decade ago 2013/04/28 19:25 JST
Hi , anyone might know ?
Posted: 1 decade ago 2013/04/29 15:12 JST
this is a delicate but very important subject, I'm very often needing this capability, but in reduced modal representation, so far I havent managed to get it working efficiently for "true models", a simple canteliever might work.
Check carefully the doc, do a search on "state space", you need to define a probe plot for the output, and define the state space export as a sub node to the solver case, with excitation in and probe out (I wounder now if it isnt rather in frequency domain you should try, rather than true transient)
Hi this is a delicate but very important subject, I'm very often needing this capability, but in reduced modal representation, so far I havent managed to get it working efficiently for "true models", a simple canteliever might work. Check carefully the doc, do a search on "state space", you need to define a probe plot for the output, and define the state space export as a sub node to the solver case, with excitation in and probe out (I wounder now if it isnt rather in frequency domain you should try, rather than true transient) -- Good luck Ivar
Posted: 1 decade ago 2013/05/01 17:23 JST
Hi , thank you for your reply.
in my project i need to define several points to measure the deflection.
it means that i need to define several probs ?
i saw the help file on this problem and tried to work with it but i had several erros on matlab.
is it possible that you will help me with pasting the commands to import the model , adding the probs until i will get reduced matrices ?
thank you in advance for your help.
Hi , thank you for your reply. in my project i need to define several points to measure the deflection. it means that i need to define several probs ? i saw the help file on this problem and tried to work with it but i had several erros on matlab. is it possible that you will help me with pasting the commands to import the model , adding the probs until i will get reduced matrices ? thank you in advance for your help.
Posted: 1 decade ago 2013/05/01 19:43 JST
have you repeated the example oh the help "state space export" for the heat_transient_axi example ?
Hi have you repeated the example oh the help "state space export" for the heat_transient_axi example ? -- Good luck Ivar
Posted: 1 decade ago 2013/07/23 23:11 JST
Dear Ivar,
I did repeat the example , but I've got the following problem:
The returned matrix MB is full of zeros so the solution obtained with ode23s is the zero solution. Hence the final y is the constant solution iqual to T0. Completely different from what it was expected.
I'm enclosing the example.
What do you think that might be wrong?
Dear Ivar, I did repeat the example , but I've got the following problem: The returned matrix MB is full of zeros so the solution obtained with ode23s is the zero solution. Hence the final y is the constant solution iqual to T0. Completely different from what it was expected. I'm enclosing the example. What do you think that might be wrong?
Posted: 1 decade ago 2013/09/13 2:43 JST
Dear all,
I finally came back to this question. I think that the comsol 4.3 tutorial doc example is not correct. Where there is:
M = mphstate(model,'sol1','out',{'Mc' 'MA' 'MB' 'C' 'D'},...
'input','T0', 'output', 'mod1.ppb1');
There should be:
'input','Tinput', 'output', 'mod1.ppb1');
In fact the input parameter's name is Tinput and not T0.
Dear all, I finally came back to this question. I think that the comsol 4.3 tutorial doc example is not correct. Where there is: M = mphstate(model,'sol1','out',{'Mc' 'MA' 'MB' 'C' 'D'},... 'input','T0', 'output', 'mod1.ppb1'); There should be: M = mphstate(model,'sol1','out',{'Mc' 'MA' 'MB' 'C' 'D'},... 'input','Tinput', 'output', 'mod1.ppb1'); In fact the input parameter's name is Tinput and not T0.
Remi Magnard COMSOL Employee
Posted: 1 decade ago 2013/09/13 21:45 JST
Dear Jorge,
There is indeed a typo in the LiveLink for MATLAB 4.3b documentation, one should read:
M = mphstate(model,'sol1','out',{'Mc' 'MA' 'MB' 'C' 'D' 'x0'},...
u = 1;
T0= 1273.15;
opt = odeset('mass', M.Mc);
func = @(t,x) M.MA*x + M.MB*u;
[t,x] = ode23s(func, [0:10:190], M.x0, opt);
y = M.C*x'+M.D*u+T0;
where T0 is the Temprature value around the linearization point.
Thank you for pointing this out!
Rémi Magnard
Dear Jorge, There is indeed a typo in the LiveLink for MATLAB 4.3b documentation, one should read: M = mphstate(model,'sol1','out',{'Mc' 'MA' 'MB' 'C' 'D' 'x0'},... 'input','Tinput', 'output', 'mod1.ppb1'); u = 1; T0= 1273.15; opt = odeset('mass', M.Mc); func = @(t,x) M.MA*x + M.MB*u; [t,x] = ode23s(func, [0:10:190], M.x0, opt); y = M.C*x'+M.D*u+T0; where T0 is the Temprature value around the linearization point. Thank you for pointing this out! Rémi Magnard
