Control Mesh element distribution over the surface
Posted 2013/04/29 11:10 GMT-4 Acoustics & Vibrations, Mesh, Structural Mechanics Version 4.3a 5 Replies
you can set variables or parameters in the mesh "size" node under "custom mesh settings" there are some examples in the model library for an RF system where the mesh density is adjusted to the wavelength and indx of the material.
To remesh for different cases, you ned to use a Parametric Sweep node BEFORE your solver node in a study
thanks a lot for your response. But I think you did not get my main problem or may be I did not explained it well. I do not want to add parametric mesh or remesh my structure. want I want is : control the number of mesh (means increase the number of mesh) in a surface of adjacent two 3D object. (refer to my problem above) In fact In comsol there is meshing option by the name of "Distribution" and I emphasize that "Distribution" Icon in meshing, that increase the number or distribution of mesh over the edge of a 2D or 3D domain. Now I want two increase (control) the distribution of mesh only and only over a surface of a 3D object (not all of it). like what "Distribution" does for the edge of 3D Domain.
Thanks, If you could help me.
I beleive we more or less understand each other ;)
I used the Szie node as example, but the dimension/ distribution node works too. Have you noticed you can set them up as global (alone high up, or as sub node to a given mesh node. You might also add several to have different densitites on different entities.
The only thin is that you MUST select the entities when you set up your mesh tree, the entities cannot be defined via variables.
But then you have also the" refinement" node that allows to select entities and make them finer , or select a "box of coordinates and make that volume finer
My only advise, start with lowest entity dimmension i.e edges first, then boundaries then domains when you set up your meshing strategy. Also if the boundaries or meshes makes loops (i.e. torus) and you geoemtry is complex, it's often worth to mesh one half end then the other, and be sure you volumes are cut up, i.e. along XY, YZ, XZ planes
Hi.
For sure you were right. :)
Thanks a lot for your help.
It was solved.
