Error in Fluid Structure Interaction
Posted 2025/07/29 5:14 GMT-4 Computational Fluid Dynamics (CFD) 0 Replies
Dear all, I am trying to simulate a closed rotating cylinder with a solid object like cube or ball which will be displaced due to the rotation of the cylinder (The cylinder is filled with water). Maximum no of newton iteration reached, i also tried direct solver which normally worked when i had convergence errors in other models i had done. Also what type of boundary condition should be given for the object?. I had given moving mesh to the fluid domain and also prescribed displacement for the solid body.
Thank you for your time
Hello Vikash P
