2013/05/06 3:31 JST
Update: I've managed to run on upto 200k Q which gives me 5 degree increase in temperature. However, If i continue to increase Q, the simulation keeps giving that NAN error.
2013/05/07 15:35 JST
you could try to map your metal layer with at least two elements in the thickness, and then more serious, I do not believe you are in truly laminar flow at that air velocity, which means among other you need a finer mesh, furthermore, heating with 1[MW]/(0.6[m^3]) seems very high, but it might be correct, but you will get quite some local gradients, hence you need a fine mesh on the solid air face
2013/05/09 7:27 JST
Thanks for the reply. I will attempt to fine the mesh as much as possible, however I'm working on a laptop so I might not be able to do so.
I do have additional questions. Is it possible to obtain the heating of the leading edge by some other boundary condition than the heat source? Right now I'm specifying the temperature at the bottom of the leading edge and that is giving expected results. However, I want to be able to do it in some sort of q value at the boundary condition.
[QUOTE]
[/QUOTE]
