Edgar J. Kaiser
Certified Consultant
10 months ago
2025/08/21 13:58 GMT-4
Hi Breno,
I am frequently having similar issues with complex post processing.
Defining variables doesn't help because they get evaluated again when called in post processing. One workaround can be to define global state variables and assign the variables to them. State variables are stored in the solution and are available without reevaluation. States do not carry a unit and you must take care of the units by yourself.
Expensive expressions are obviously calculated much faster within the solver code than in post processing code.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Breno,
Cheers
Edgar
Breno
Topology optimization and Finite Element specialist
10 months ago
2025/08/22 7:59 GMT-4
Hello Edgar,
I like the idea. Though, after trying to implement it, after about 3 hours of solution, it stopped with an error, where apparently a variable was not defined (?). This seems difficult to debug. I'd need to start small with, e.g. that view factor tutorial. If you use state variables, COMSOL has to "compile" that in the equations, right? Or maybe I just set them up wrong...
I used "Boundary" geometric entities for my state variables, because they have to be evaluated as boundary surface integrations, but also set an order of 0, since they are scalars. I'm not sure if this is correct. Additionally, I set "Update: Only Initialization". Maybe there's a simplification that can be done in the Study/Solver node to improve performance?
Anyway, in the end I "solved" my problem by using normal variables in one file, running the problem, saving the file with the results, then copying and pasting this file multiple times. Open each of these files, and finally Evaluate different sets of expressions in each of them, in parallel. Definitely far from a pretty solution, but it works.
Cheers,
Breno
Hello Edgar,
Cheers,
Breno
Edgar J. Kaiser
10 months ago
2025/08/22 10:46 GMT-4
Hi Breno,
I understood that you are calculating integrals and the integral is a global value that doesn't need to be tied to a geometric entity.
I am only using global states.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Breno,
Cheers
Edgar
Walter Frei
COMSOL Employee
9 months ago
2025/09/03 14:45 GMT-4
Updated:
9 months ago
2025/09/03 14:58 GMT-4
Hello Breno,
There can be different ways of doing this that can be more efficient, yes. It does also though raise the question as to why you want to compute all of these terms? That is, once you have the terms of the view factor matrix, what do you plan to do with them? I realize that this may be an involved question specific to your workflow, so if you wish to open a support case we can also discuss this more privately.
Walter Frei, PhD
COMSOL Support
Hello Breno,
Walter Frei, PhD
COMSOL Support
Edgar J. Kaiser
9 months ago
2025/09/04 3:32 GMT-4
Hi Walter,
good to see you kicking in. In some cases there is no way around doing complex operations in the data, such as integrals and averages. In such cases the postprocessing can be more costly than the solution. I successfully worked around in some cases by using the global states.
Can you suggest other more efficient ways?
Thank you,
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Walter,
Thank you,
Edgar
