Robert Koslover
Antennas, Waveguides, Electromagnetics
1 year ago
2025/09/11 10:05 GMT-4
Updated:
1 year ago
2025/09/11 10:08 GMT-4
You appear to have placed conducting boundaries around ALL the edges of your lumped ports. That is not the right way. You are shorting out the ports -- look at your settings under Perfect Electric Conductor 1 and Perfect Electric Conductor 2. The electric field in each rectangular port should travel perpendicularly from one conducting edge of a port to the opposite, parallel edge of the port. It should not travel along a conducting edge, since that would short out the port.
You appear to have placed conducting boundaries around ALL the edges of your lumped ports. That is not the right way. You are shorting out the ports -- look at your settings under *Perfect Electric Conductor 1* and *Perfect Electric Conductor 2*. The electric field in each rectangular port should travel perpendicularly from one conducting edge of a port to the opposite, parallel edge of the port. It should not travel *along* a *conducting* edge, since that would short out the port.
1 year ago
2025/09/11 12:10 GMT-4
thank you for such fast response, I will correct this
1 year ago
2025/09/12 12:19 GMT-4
Updated:
1 year ago
2025/09/12 14:20 GMT-4
Hi, I want to run the simulation of CPW resonator with capacitively coupled with lamped port . But there I can not generate the S21 plot, can anyone help...
