2013/05/09 23:02 JST
I am currently working on bio-compatible material based sensor, where i want to use PDMS (Polydimethylsiloxane) as a membrane.But I can not get Elasticity matrix,voigt notation(mechanical properties) of PDMS for simulation.
Do any of you know the Elasticity matrix,voigt notation of PDMS?
PDMS can have a large range of properties depending on the monomer to hardener ratio. Also, I am not aware that PDMS would have to be modeled anisotropically, you can try isotropic settings and avoid directly having to input into the C-tensor. For what it is worth, I commonly use these values for bulk PDMS. p-wave speed = 1020 m/s, shear wave speed = 25 m/s and density = 1040 kg/m^3.
Adding in damping is a whole other issue, and important one. Also, depending on how thin your membrane is ... this might not be right, if scale dependent issues arise. Also also, I've only described a linear approximation, PDMS is hyperelastic and often is modeled that way. Modeling these soft elastomers can be tricky. So basically, I can't help very much.
~Chris
[QUOTE]
[/QUOTE]
~Chris
2013/05/10 16:16 JST
Thank you for your suggestion.
