Plot of temperature along a line inside of a thin layer
Hello
How can we plot the temperature along a line inside a thin layer? The line is parallel to the thin layer surface. I manage to do the surface graph of the temperature on the layer, but I would like to do the plot of the temperature only on a line. I've tried several approaches with the command atxd but they didn't succeed.
Thank you
5 Replies Last Post 2025/10/09 10:08 GMT-4
Posted: 9 months ago 2025/10/01 15:01 GMT-4
Margarida,
a cut line dataset and a line plot using it is what you want.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Margarida, a cut line dataset and a line plot using it is what you want. Cheers Edgar
Posted: 9 months ago 2025/10/06 12:32 GMT-4
Thank you, Edgar. A cut line 2D or 3D? I tried to use a cut line 3D but using 2 points but I couldn't figure out right z-coordinate of those two points (my thin layer is in the plane xy).
Posted: 9 months ago 2025/10/07 2:21 GMT-4
Updated: 9 months ago 2025/10/07 5:39 GMT-4
If the layer is in the xy plane, then z should be 0?
If the thin layer is implemented as a boundary you may see a temperature discontinuity. In this case you can use the up() and down() operators to see the temperatures on each side of the boundary.
Edgar J. Kaiser
www.emphys.com
If the layer is in the xy plane, then z should be 0? If the thin layer is implemented as a boundary you may see a temperature discontinuity. In this case you can use the up() and down() operators to see the temperatures on each side of the boundary.
Posted: 9 months ago 2025/10/07 10:01 GMT-4
The layer is a xy plane at a particular z=z0. The layer has thickness but there is no z-coordinate associated with it since it was defined as layered material. If I use the cut line 3D, I can choose the layered material that I previously selected as one dataset, I choose the x and y coordinates accordingly to the line I want but I could not find the right z to use. I tried the z0, zero (as you suggested ) and other options but I could not find the right z choice. Have you got other suggestions?
Thank you.
The layer is a xy plane at a particular z=z0. The layer has thickness but there is no z-coordinate associated with it since it was defined as layered material. If I use the cut line 3D, I can choose the layered material that I previously selected as one dataset, I choose the x and y coordinates accordingly to the line I want but I could not find the right z to use. I tried the z0, zero (as you suggested ) and other options but I could not find the right z choice. Have you got other suggestions? Thank you.
Posted: 9 months ago 2025/10/09 10:08 GMT-4
I suggest that you post your .mph file to the forum.
