Making Kymograph plot?
Jens-Christian Meiners
I'm fairly new to Comsol and have difficulties with the following: I have a time-dependent simulation that gives me a concentration as a function of space and time. The geometry and simulation is axially symmetric. I'd like to make a kymograph plot where one axis is time and the other is r, with color coding of the concentration. How can I make this happen? Thank you!
1 Reply Last Post 2025/11/18 8:06 GMT-5
Posted: 8 months ago 2025/11/18 8:06 GMT-5
You can create an Edge 2D dataset for the edge along which you want to plot the result.
Then, add a Parametric Extrusion 1D, and set Dataset to the one you just created.
This will give you a plot with the spatial coordinate on the horizontal axis, and time on the vertical, but maybe that suffices?
Henrik Sönnerlind
COMSOL
You can create an *Edge 2D* dataset for the edge along which you want to plot the result. Then, add a *Parametric Extrusion 1D*, and set *Dataset* to the one you just created. This will give you a plot with the spatial coordinate on the horizontal axis, and time on the vertical, but maybe that suffices?
