Optimization of an electron beam radius
Good morning, I am performing a simulation for an electron accelerator which consists of a cathode, an initial accelerating potential and then the electron beam is guided by six coils on a target which is almost 1m far from the cathode. The simulation itself is ok and I can see the beam.
What I'd like to do next is performing an optimization of the radius of the beam with respect to the currents in the coils. To do so, I defined a boundary probe on the surface of my target with the expression called R_spot, where qy and qz are the position of particles in y and z.
Then I set up an optimization with objective function (spot_target - comp1.R_spot) where spot_target is defined as 1[mm] in my parameters. I ask for a minimization with control variables the six coils currents. But I keep getting this error and I don't understand how to resolve:
Error in sweep. - Parameters: "I_coil_1","20","I_coil_2","20","I_coil_3","20","I_coil_4","20","I_coil_5","20","I_coil_6","20" Cannot evaluate expression. Undefined variable. - Variable: comp1.qy - Geometry: geom1 - Boundary: 87 Failed to evaluate expression. - Expression: sqrt((comp1.qy^2)+(comp1.qz^2)) Failed to evaluate expression. - Expression: comp1.bnd1_operator1(sqrt((comp1.qy^2)+(comp1.qz^2))) Failed to evaluate variable. - Variable: comp1.R_spot - Defined as: comp1.bnd1_operator1(sqrt((comp1.qy^2)+(comp1.qz^2))) Failed to evaluate variable. - Variable: opt.obj1
I also watched the Optimization tutorials in the Learning Center. If someone can help me figuring out what I'm doing wrong I will be grateful since I'm few days into Comsol and I'm learning it by myself. Thank you in advance, Emanuele
2 Replies Last Post 2025/12/13 8:27 GMT-5
Deepak Shah COMSOL Employee
Posted: 7 months ago 2025/12/10 11:31 GMT-5
Hi Emanuele, the variables in your expression are defined on particles and are not global variables. Please use in the Boundary Probe 1 node, which has global scope.
Hi Emanuele, the variables in your expression are defined on particles and are not global variables. Please use cpt.max(sqrt(qy^2 + qz^2)) in the Boundary Probe 1 node, which has global scope.
Posted: 7 months ago 2025/12/13 8:27 GMT-5
Thank you very much! I resolved the issue.
>Hi Emanuele, the variables in your expression are defined on particles and are not global variables. Please use cpt.max(sqrt(qy^2 + qz^2)) in the Boundary Probe 1 node, which has global scope. Thank you very much! I resolved the issue.
