Hello Hans Parmentier
2013/08/19 23:06 JST
same problem here.
I want all the derived values to appear in one table. Sometimes this happens automatically, sometimes not.
Is there any solution to that problem? Because I couldn´t find any option where I can specify the table in which the derived values shall appear...
same problem here.
2013/08/20 0:17 JST
Hi Hans,
for the derived values that you use (Point or Global evaluation), on the button with the orange symbol of equal = (Evaluate button) there is the list of tables. Therefore, you can choose to store your values in a defined table or in a new table
Hope this helps
Regards
Hi Hans,
Hope this helps
Regards
2013/08/20 19:56 JST
Thank you. That is exactly the option I was looking for!
2014/06/27 16:32 JST
While this proposed solution will work, it means that in order to combine all, or selected, derived values into a single table the program must recalculate the values, which is a waste of time for what should be a simple copy/paste operation.
Burying the table assignment in the evaluate menu obscures this option and unnecessarily links it to the evaluation. Instead there should a clear option in the derived value UI to indicate on which table a given value will be placed, and a correlated option in the table UI to define which values appear on a given table. If the values have already been calculated, then a change of these options should trigger a move or copy of the values to the new table. Then the table reconfiguration is clear and fast.
