Possibility to import a 2D CAD file to COMSOL?
I am running the last version of COMSOL (4.3b). I tried to import a 2D CAD file to COMSOL but failed to do so! Generally, is it possible to import a 2D CAD file to COMSOL or only 3D files? If so, through which format?
Your prompt reply will be greatly appreciated!
Many thanks in advance,
Afshin
9 Replies Last Post 2017/07/29 8:43 GMT-4
Posted: 1 decade ago 2013/05/22 11:55 GMT-4
You can import 2D CAD files without the CAD module. You need to have the drawings as .DXF files.
Sven Friedel COMSOL Employee
Posted: 1 decade ago 2013/05/22 11:59 GMT-4
a 2D CAD file for instance DXF or DWG can be imported in a 2D COMSOL geometry.
Moreover, in a 3D COMSOL Geometry, you can create a workplane (which is a 2D geometry).
There you can import the above 2D CAD file and then embed or extrude it into the 3D geometry.
Best regards
Sven
Hi, a 2D CAD file for instance DXF or DWG can be imported in a 2D COMSOL geometry. Moreover, in a 3D COMSOL Geometry, you can create a workplane (which is a 2D geometry). There you can import the above 2D CAD file and then embed or extrude it into the 3D geometry. Best regards Sven
Posted: 1 decade ago 2013/05/22 12:37 GMT-4
Many thanks for the hints. My problem was solved by your helps. :)
Afshin
Hi, Many thanks for the hints. My problem was solved by your helps. :) Thanks, Afshin
Posted: 9 years ago 2016/09/21 3:43 GMT-4
Hi all,
I have a problem related to importing a 2D model in Comsol.
The 2D model has been exported from Solidworks as step or iges. This format is not applicable to import in Comsol 2D. So, to overcome that, I produced a dxf file ,but, while it is applicable to import, I always get an error that there is no geometry to import.
Please can you advice further?
Kind regards,
Pavlos.
Hi all, I have a problem related to importing a 2D model in Comsol. The 2D model has been exported from Solidworks as step or iges. This format is not applicable to import in Comsol 2D. So, to overcome that, I produced a dxf file ,but, while it is applicable to import, I always get an error that there is no geometry to import. Please can you advice further? Kind regards, Pavlos.
Posted: 9 years ago 2016/10/27 9:59 GMT-4
hello~
I also met this problem when I imported a 2D CAD file which is DXF fomat. Have you solved it yet?
Your reply will be appreciated. Thanks a lot
Wei Rui
hello~ I also met this problem when I imported a 2D CAD file which is DXF fomat. Have you solved it yet? Your reply will be appreciated. Thanks a lot Wei Rui
Posted: 9 years ago 2016/10/27 23:27 GMT-4
Hi Sven
I want to import a 2D CAD file for instance DXF or DWG in a 2D COMSOL geometry.
But I get the error 'The file contains no geometry objects of the requested type.'
Do you know how can I solve it?
Your reply will be greatly appreciated. Thanks a lot.
Wei Rui
Hi Sven I want to import a 2D CAD file for instance DXF or DWG in a 2D COMSOL geometry. But I get the error 'The file contains no geometry objects of the requested type.' Do you know how can I solve it? Your reply will be greatly appreciated. Thanks a lot. Wei Rui
Posted: 9 years ago 2017/05/02 1:01 GMT-4
Updated: 9 years ago 2017/05/02 1:02 GMT-4
Set layers before import in dxf file.Then import the file with selected layer in geometry import.
Posted: 8 years ago 2017/06/06 1:39 GMT-4
I have saved my 2D .dwg design of AutoCAD in .dxf format for importing into COMSOL. I selected the layers also, but still the 2D .DXF file is not getting imported in COMSOL. Is there any oter way to import the .dxf or .dwg file?
Posted: 8 years ago 2017/07/29 8:43 GMT-4
Hi @Sven Friedel. I have solidworks 2013 and Comsol 5.1, when I try to save the 2D draw as DXF, it does not work (idem for .mph and .dwg). I click on save, but the file is not created.
Thank you for your help.
Hi @Sven Friedel. I have solidworks 2013 and Comsol 5.1, when I try to save the 2D draw as DXF, it does not work (idem for .mph and .dwg). I click on save, but the file is not created. Thank you for your help.
