Heat source: Temperature profile instead of heat
Posted 2013/05/22 11:56 GMT-4 Heat Transfer & Phase Change Version 4.3a 7 Replies
I want to use measured values to define a heat source in the "Conjugate Heat Transfer". I could already generate a 3D-function of these values which can be used as Q. But my problem is that the values are temperatures in Kelvin and not a heat in W/m^3.
So does somebody now how to use a temperature profile instead of the heat?
Sandra
For small transients could be a way for emulate a constant heat source.
thank you for your answer.
But I do not really understand what you mean. Maybe the idea is to choose a high heat capacity in order to get similar values of Q and T? I hoped for an easier way to just use the temperature. But I will think it over.
Sandra
Sandra,
if I understand you correctly it is easy. Use a temperature boundary condition and assign your temperature function to it.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
at first I tried it with the temperature boundary condition like you suggested. But I have a 3 dimensional temperature distribution in an 3D-area and not only on a boundary. I do not only want to set a temperature distribution on the surface of e.g. an ellipsoid but there should also be a temperature value for every point inside of it.
Correct me if I'm wrong but I don't think that it is possible to use the temperature boundary condition for this purpose.
Sandra
Sandra,
I would say that the inside of the domain doesn't contribute to the model if it just remains at a fixed temperature. Only the boundary interacts with the 'variable' part of the model.
But I may still not completely understand what you are after exactly.
Edgar J. Kaiser
www.emphys.com
you're right, usually it would be like this. I forgot to mention that I want to have this temperature contribution in every point because I want a laminar flow to go through this area. So I don't want to define a solid with a temperature on its surface but an area with the same properties like the flowing fluid.
The reason for this is that later I want to simulate a plasma with a fluid flow. But as a first step and since I got the measured temperature profile of the plasma my idea was to just set up an area with this temperatures to find out how the heat would affect the fluid flow.
Sandra
Well, then you might try to do it Francesco's way. Your attempt is a bit 'unphysical' because T is the dependent variable.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Suggested Content
- BLOG Modeling the Pulsed Laser Heating of Semitransparent Materials
- FORUM Loss in heat instead of heat flux at boundary?
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling? - FORUM Transient Heat conduction with Input as Intensity Instead of temperature
- BLOG 4 Methods to Account for Radiation in Participating Media
