Using Heat Release Rate (HRR) vs. Temperature-Time Curve as Input
I am modeling a fire scenario in COMSOL and have the fire defined by a Heat Release Rate (HRR, kW) versus time curve. Is it possible to use an HRR-time curve directly as an input in COMSOL? Can a tabulated HRR-time function be imported and used directly as a time-dependent heat source? My objective is to model the thermal response of a structure subjected to a fire characterized by a measured/design HRR-time history. Any guidance or example models would be greatly appreciated. Thank you.
2 Replies Last Post 2026/11/16 10:59 GMT-5
Robert Koslover RF/Antennas
Posted: 3 weeks ago 2026/10/26 21:25 GMT-4
Updated: 3 weeks ago 2026/10/26 23:14 GMT-4
Edited: Yes, you should be able to import a text or csv formatted set of tabulated measured values vs. time, to use in your time-domain model as part of a source specification. You should probably should import the data into an interpolated function. Include some smoothing, so your time-domain model won't struggle with an unphysical ragged definition.
Robert A. Koslover
Posted: 29 minutes ago 2026/11/16 10:59 GMT-5
Thank you for the earlier response. I imported my HRR-time curve as an interpolation function HRR_V1(t) and applied it using Heat Flux → Heat Rate, with P0=HRR_V1(t). My understanding is that COMSOL converts this to an equivalent heat flux q(t)=HRR(t)/Aq(t) using the selected boundary area. Is this interpretation correct?
Reply
