Nagi Elabbasi
Facebook Reality Labs
2013/05/30 7:19 JST
You can use modal damping coefficients in a frequency analysis if it is a modal frequency analysis. In that case you directly input the damping ratios in the Modal Solver settings.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
2013/05/30 18:38 JST
Nagi Elabbasi
Veryst Engineering
Dear Nagi,
Thanks for this response.
Modal frequency analysis is the frequency analysis that uses the modal superposition principle but not the direct solver option(where a different linear system is solved at each frequency to end up with the frequency response function), is this correct?
Umut
[QUOTE]
Nagi Elabbasi
Veryst Engineering
[/QUOTE]
Dear Nagi,
Umut
2013/05/30 20:20 JST
Nagi Elabbasi
Veryst Engineering
Dear Nagi,
Do you have a simple example for a modal frequency analysis where damping ratios are specified?
BR,
Umut
[QUOTE]
Nagi Elabbasi
Veryst Engineering
[/QUOTE]
Dear Nagi,
BR,
Umut
Nagi Elabbasi
2013/05/30 22:39 JST
Dear Umut,
Yes, modal frequency analysis is based on modal superposition. There is an example file called elbow_bracket in the COMSOL models that shows how to setup a model frequency analysis. By default it does not use modal damping ratios (therefore they are set to zero). However, you can change that easily in the Modal Solver settings window.
Nagi Elabbasi
Veryst Engineering
Dear Umut,
Nagi Elabbasi
Veryst Engineering
