Warning: Parametric solver does not support geometry and mesh dependent parameters
Posted 2013/05/30 3:36 GMT-4 Version 5.0 1 Reply
I want to sweep a parameter, but the geometry and mesh depend on the parameter. Then I get the warning message
Parametric solver does not support geometry and mesh dependent parameters.
I found a related discussion thread, where Ivar replied
In which context did you get that error, if you have selected a Solver Continuation parametrical sweep then it is because that is NOT looping over the geoemtry and the mesh.
To perform a parametric sweep to change the geoemtry and to remesh you need to add a separate "parametric Sweep" node before your solver node
Does anyone know how to add the separate "parametric sweep" node?
Thanks!
Hello Pu Zhang
