"segiter" ?
Hello!
I need a help please.
what is the parameter "segiter" in pairs contact?
4 Replies Last Post 2013/06/03 3:54 GMT-4
Posted: 1 decade ago 2013/05/31 8:33 GMT-4
'segiter' is the 'number of the iteration in the segregated solver'. It is used for relaxing the penalty factor during the first iterations when large overclosures may occur.
From version 4.3b, the corresponding expression instead contains the variable niterCMP which is more general. It is the 'number of the nonlinear iteration', which is defined also for a fully coupled solver.
Henrik
Hi, 'segiter' is the 'number of the iteration in the segregated solver'. It is used for relaxing the penalty factor during the first iterations when large overclosures may occur. From version 4.3b, the corresponding expression instead contains the variable niterCMP which is more general. It is the 'number of the nonlinear iteration', which is defined also for a fully coupled solver. Regards, Henrik
Posted: 1 decade ago 2013/05/31 8:46 GMT-4
where i find the value of this parameter ? The default value.
Thank you
where i find the value of this parameter ? The default value. Thank you
Posted: 1 decade ago 2013/05/31 10:23 GMT-4
Thank you
It is the iteration counter. 1 in the first iteration, 2 in the second etc.
Henrik
[QUOTE] where i find the value of this parameter ? The default value. Thank you [/QUOTE] It is the iteration counter. 1 in the first iteration, 2 in the second etc. Regards, Henrik
Posted: 1 decade ago 2013/06/03 3:54 GMT-4
Thank you
Thank you
