B-H curve for Soft Iron
Hello there !
I am about to use (soft iron) as a core for a saturable device . I need to specify the H( knee) & B(sat) points, but the listed values of B & H in the BH curve seem to away different from what I've found in this link:
www.fieldp.com/magneticproperties.html
Could you help me in figuring out what is the problem !
6 Replies Last Post 2016/04/05 14:29 GMT-4
Posted: 1 decade ago 2013/06/12 2:37 GMT-4
the webpage that your link points to has data of relative permeability, but the BH(or HB)-curves
in Comsol have the magnetic field strength. Is that was is different? I did not convert the that
to check.
Regards
Jens
Hello, the webpage that your link points to has data of relative permeability, but the BH(or HB)-curves in Comsol have the magnetic field strength. Is that was is different? I did not convert the that to check. Regards Jens
Posted: 1 decade ago 2013/06/12 8:03 GMT-4
That's right, but if you tried to convert, there will be a huge difference !.
Can anyone at least provide the H(knee) for Soft Iron?
Thanks Jens,
That's right, but if you tried to convert, there will be a huge difference !. Can anyone at least provide the H(knee) for Soft Iron? Thanks Jens,
Posted: 1 decade ago 2013/06/12 23:12 GMT-4
The following is useful, at least for relatively strong fields.
First, recall that B = mu_0 * mu_r * H
For type-1010 steel (which has much similarity to soft iron) the following expression provides a reasonable fit over a wide range:
mu_r = 1.0 + 2500*(1-tanh(2.7*B)^450)
where B is expressed in Tesla.
tanh = hyperbolic tangent.
So, to clarify: Compute tanh of 2.7*B. Then raise that to the 450 power. Subtract that result from 1. Multiply by 2500. Then add 1. And that will get you a surprisingly good approximation to mu_r.
I hope that helps.
The following is useful, at least for relatively strong fields. First, recall that B = mu_0 * mu_r * H For type-1010 steel (which has much similarity to soft iron) the following expression provides a reasonable fit over a wide range: mu_r = 1.0 + 2500*(1-tanh(2.7*B)^450) where B is expressed in Tesla. tanh = hyperbolic tangent. So, to clarify: Compute tanh of 2.7*B. Then raise that to the 450 power. Subtract that result from 1. Multiply by 2500. Then add 1. And that will get you a surprisingly good approximation to mu_r. I hope that helps.
Posted: 1 decade ago 2013/06/13 9:33 GMT-4
That's helpful
I don't know how to thank you Robert :)
But can I ask how could one get like this expression for other Ferro's ?
regards
That's helpful I don't know how to thank you Robert :) But can I ask how could one get like this expression for other Ferro's ? regards
Posted: 10 years ago 2016/03/08 11:46 GMT-5
Hi Robert,
Could you please give me the reference for this equation:
With regards,
Sumeet
Hi Robert, Could you please give me the reference for this equation: mu_r = 1.0 + 2500*(1-tanh(2.7*B)^450) where B is expressed in Tesla. tanh = hyperbolic tangent. With regards, Sumeet
Posted: 10 years ago 2016/04/05 14:29 GMT-4
It was from my ad-hoc curve fit to B vs. H data tabulated in Fig. 3, page 5 of: Yadav, S., "Finite Element Magnetic Analysis of the Cornell Three-Pole Wiggler Model," Fermi National Accelerator Laboratory (Fermilab) report TD-01-067, Sept. 28, 2001. Note that the report states that the data were "taken from Opera."
