Sergei Yushanov
Certified Consultant
2013/07/02 0:40 JST
Khalid,
Attached is model of multi-turn coil with two symmetry planes.
Sergei
Khalid,
Sergei
2013/07/02 6:56 JST
Hello Sergei
Thanks for your model file. I have gone through the model you provided but I dont understand the meaning of perfect magnetic conductor here in this context. In addition I tried to add perfect magnetic conductor in my model but it gives me an error "failed to find a solution, system matrix in zero".
I have also added output, as I have read doc that states that adding magnetic conductor will not violate current conservation which in my case is output? am i right or I am not specifying right boundary condition?
I have attached my model, its a copper coil excited with 30 A with surrounded air
Hello Sergei
Sergei Yushanov
2013/07/02 20:57 JST
Khalid,
Perfect Magnetic Conductor (PMC) boundary condition
nxH=0
states that tangential component of magnetic field is zero at the boundary, meaning that magnetic field is normal to that boundary. In your case, this would be appropriate choice to account for symmetry plane at z=0.
I made couple changes in your setup and put my comments. Attached is your working model.
Sergei
Khalid,
nxH=0
Sergei
2013/07/03 0:48 JST
Thanks Sergei for your model, actually I have built my 2D axis symmetric, 2D and complete 3D models. But in this simple model as you suggested that the symmetry plane would be at z=0 but I wud also be adding a metal beneath this coil and after adding that in the model I get wierd results, there is no magnetization of the metal and it seems like solver is not taking the metal into consideration. I wonder why this symmetery calculations becomes so complex.
Any thoughts would be really helpful
Regards
Khalid
Regards
Khalid
Sergei Yushanov
2013/07/03 21:13 JST
Khalid,
Seems that you mesh of the metal beneath the coil is not adequate. Generally, meshing strategy of the metal depends on the excitation frequency. Calculate skin depth and compare it to the dimensions of you metal object. You may need to resolve skin depth using Boundary Layer Mesh (BLM) or exclude metal part from computational domain and model only the fields and induced current on the surface of the metal using Impedance Boundary Condition.
Hard to give specific answer based on such general description of your issue.
Sergei
Khalid,
Sergei
