How to cut a geometry
I have a 3D geometry and I need to cut half of it to create a symmetry plane.
Can you please describe the steps.
Thanks.
Dimitris
3 Replies Last Post 2013/08/23 15:39 JST
Josh Thomas Certified Consultant
Posted: 1 decade ago 2013/07/12 21:39 JST
Dimitris,
If you are using v4.3b the steps have been simplified a bit from previous versions.
Simply define a work plane that slices your geometry across the symmetry plane: (Right-click on Geometry and select Work Plane.)
Then, partition. (Right-click on Geometry and select Boolean Operations>Partition)
Add the object to partition to the list. Then select to "Partition with:" Work Plane and select your work plane.
(You can then use a Delete Entities operation to delete half your geometry if desired.)
Josh Thomas
AltaSim Technologies
Dimitris, If you are using v4.3b the steps have been simplified a bit from previous versions. Simply define a work plane that slices your geometry across the symmetry plane: (Right-click on Geometry and select Work Plane.) Then, partition. (Right-click on Geometry and select Boolean Operations>Partition) Add the object to partition to the list. Then select to "Partition with:" Work Plane and select your work plane. (You can then use a Delete Entities operation to delete half your geometry if desired.) Best regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago 2013/08/22 17:59 JST
how can we cut geometry in version 4.2
Posted: 1 decade ago 2013/08/23 15:39 JST
Add a block and subtract it from your geometry. Then use symmetry boundary condition on the intersection.
