Convection in a domestic space (beginner)
Posted 2010/03/16 6:29 JST 1 Reply
The problem I am trying to model is that of a radiator heating a room.
I am intending to use the model to see how long it takes the room to warm up so that there is an even
temperature distribution. Once this is found, a fan will be placed somewhere in the room to set up a forced convection cycle. Then I want to be able to find out if this can heat up the centre of the room quicker.
I am new to Comsol and - only having some knowledge of Ansys for vibration problems - I am a little unsure on how to go about fixing the problem.
Currently I have been following some of the tutorials from comsol help or the model gallery, but I cannot find a solution that converges when I try to adapt them to my model.
I was wondering how best to set up the heat transfer boundary conditions? I know some heat has to be lost in the model but i am unsure how to set this up realistically.
When the solver stops, the (junk) solution that was given showed the convection current in the velocity field as i expected it, but the heat does not seem to be transferring with the fluid flow.
Thank you very much for any help you can offer.
James
James
1 Reply Last Post 2010/03/17 1:40 JST
