adding new property
How to add new property to the material such as Seebeck coefficient? This is not available in COMSOL property list
4 Replies Last Post 2016/04/04 11:42 GMT-4
Hello Susant Patra
Posted: 1 decade ago 2014/12/28 8:19 GMT-5
Hi Susant,
I'm a new learner and i am facing the same problem as yours. Did you able to add the Seebeck coefficient now?
I'm using comsol version 4.2.
Thank you.
Aqilah
Hi Susant, I'm a new learner and i am facing the same problem as yours. Did you able to add the Seebeck coefficient now? I'm using comsol version 4.2. Thank you. Aqilah
Posted: 1 decade ago 2014/12/29 8:13 GMT-5
Maybe you should update your comsol version. I'm sure comsol 4.4 has Seebeck coefficient just under the basic property of material property.
Hi, Maybe you should update your comsol version. I'm sure comsol 4.4 has Seebeck coefficient just under the basic property of material property.
Posted: 10 years ago 2016/02/15 17:33 GMT-5
Hi, none of the above really answers the question... I'm stumbling on a similar one at the moment; Joule Thomson coefficient.
Yes, I could wait for COMSOL 6.8 and yes JT might be on that one.
But is there a way to add material properties to the existing list?
Thanks, John
Hi, none of the above really answers the question... I'm stumbling on a similar one at the moment; Joule Thomson coefficient. Yes, I could wait for COMSOL 6.8 and yes JT might be on that one. But is there a way to add material properties to the existing list? Thanks, John
Posted: 10 years ago 2016/04/04 11:42 GMT-4
In general when faced with problems like these, I would
recommend to tage a step back and refresh your mind with information on your subject matter, in this case
the Seebeck Coefficent.
I really like the explanations given on here: www.linseis.com/en/our-products/seebeck-coefficient-electric-resistivity/
Should be easy to understand and also help with your problem in Comsol
In general when faced with problems like these, I would recommend to tage a step back and refresh your mind with information on your subject matter, in this case the Seebeck Coefficent. I really like the explanations given on here: http://www.linseis.com/en/our-products/seebeck-coefficient-electric-resistivity/ Should be easy to understand and also help with your problem in Comsol
