                                2 decades ago
                                2010/03/17 13:12 GMT-4
                                                    Is there anyone could help me? This problem is really strange...
I have checked...at some point I already got a zero flux at boundary which means the concentration will remain the same but it was not...The concentration still decrease...I am confused by this results because the boundary flux was already zero how can I get decreased concentration even minus concentration?
I read from the  Knowledge Base that we could use smooth step function to avoid this but I did not really get how to do it...
I will appreciate if some could help me to work this out.
Thanks!
Xin
Thanks!
Xin
                                2 decades ago
                                2010/03/17 17:49 GMT-4
                                                    I had the same problem. Seems that it results from too rude mesh.
Using "Refine Mesh" command always helped me,
though at first I have not expected that I need such a refined mesh to eliminate
large variations of concentration and its negative values.
 Good luck,
Arsen
 Good luck,
Arsen
                                2 decades ago
                                2010/03/18 5:06 GMT-4
                                                    Hi Arsen,
Thanks for your suggestions. But it was not suitable for my problem...do you have any other suggestions? Thanks a lot.
Xin
                            Hi Arsen,
Xin
                                2 decades ago
                                2010/03/18 13:35 GMT-4
                                                    It is possible that you have instability problems, which are common with high convection PDEs.
Try using "artificial diffusion". This way you will not get overshoots and undershoots around c=0. Also try refining the mesh where the element has high C.
There is a KnowledgeBase dedicated to this kind of problems. please search negative concentration.
                                2 decades ago
                                2010/03/19 12:12 GMT-4
                                                    Thanks for everyone's help. The problem is finally solved by using smoothing step function as introduced in the knowledge base.
                                2 decades ago
                                2010/03/23 12:20 GMT-4
                                                    Hello.
I have a similar problem. Could you explain me how to use the smoothing function introduced in the KnowledgeBase?
Thanks a lot.
                            Hello.
Thanks a lot.
                                2 decades ago
                                2010/03/24 6:30 GMT-4
                                                    for my case, because I have a negative concentration which I guess it is because of the boundary conditions.
the boundary condition is:
  N = kc*(Csurface-Cair)
with smoothing function
  N = flc2hs(Cair-Csurface,dC)*kc*(Csurface-Cair)
where the variable dC is a constant that defines the smoothing interval width. Define this variable on the Options>Constants menu. It will take some experimenting to find a good value; start with a large value (large enough so that negative values do not occur), then decrease it as far as possible while keeping the solution positive.
I hope it helps.
Good luck,
Xin
I hope it helps.
Good luck,
Xin
                                2 decades ago
                                2010/03/25 6:45 GMT-4
                                                    Hi.
I am very new to Comsol, and I cannot find where to write this equation.
Is it in the NS model or in the CD one ? Can you more specific please ?
Thank you so much.
                            Hi.
Thank you so much.
                                2 decades ago
                                2010/03/25 7:25 GMT-4
                                                    first, you need to make sure where you want to have this smooth function.
my example is just my case, for yours, you must think about where you want this? at boundary condition or some other expressions. then you can just put the smooth function in front of your equation.
flc2hs(a,dC)*your equation.
the equation can be at boundaries or at any global expression.
I hope it is clear now
                                2 decades ago
                                2010/04/19 5:45 GMT-4
                                                    If the dependent variable is something like mass or particle density that must always be a positive quantity, another solution is to rewrite the original DE in terms of the logarithm of the variable. This would then require using the equation form to set up the model, and the terms might be complicated, but at least you would automatically be guaranteed that the results would be positive, regardless of whatever instability that there might be because of a too-course meshing.
                                2 decades ago
                                2010/06/25 14:42 GMT-4
Hi Xin,
I am currently setting up my very first coupled convection/diffusion and fluid flow testcase in COMSOL and thus I have an extremely basic question, but I just don't see how it is done. How do you specify this flux in a case where you have convection and diffusion? Or rather how do you address the variable "C on the boundary" and "C in the flow"? Thank you very much for your help.
Franz
                            [QUOTE]
[/QUOTE]
Hi Xin,
Franz
                                2 decades ago
                                2010/06/25 16:15 GMT-4
                                                    To rephrase my question from above (I have looked all over tutorials, model files and such and could not find this): What is the proper syntax to define a Flux Discontinuity at a fluid/solid (or solid/solid) interface in the form: N = k*(c_surface - c_flow) ?
Thank you for any help on this.
Franz
Franz
                                10 years ago
                                2016/02/07 14:09 GMT-5
  I am also facing the problem of negative concentration.
I have gone through your post.
In my model when I am using the modified flux condition in your post,
   'N = flc2hs(Cair-Csurface,dC)*kc*(Csurface-Cair)'
it is displaying inconsistent units.
Can you help me with this?
                                10 years ago
                                2016/02/08 2:13 GMT-5
                                                    Function flc2hs is nagging due to inconsistent units because it is a plain function without any units. Yet, it does not harm the computation. You can try writing
flc2hs((Cair-Csurface)/C0, dC/C0)
where C0 is a parameter 1 mol/L (the standard concentration).
BR
Lasse
BR
Lasse
