using multiple Comsol Windows simultaneously on Mac OS
until now I was unable to use multiple Comsol Windows simultaneously on Mac OS. Is that feature only available with the Windows version?
Denis
4 Replies Last Post 2014/06/27 5:57 JST
Hello Denis Maus
Posted: 1 decade ago 2014/03/31 22:52 JST
did you find an answer for your question? I also working on Mac OS and would very much like to be able to open multiple comsol models at the same time.
//Ellen
Hi, did you find an answer for your question? I also working on Mac OS and would very much like to be able to open multiple comsol models at the same time. //Ellen
Posted: 1 decade ago 2014/04/09 16:18 JST
no, unfortunately i did not found a solution.
Posted: 1 decade ago 2014/06/26 22:58 JST
You can run a new instance by using the following command in the Terminal.
open -na "COMSOL Multiphysics.app"
Procedure to open from COMSOL installation directory:
1.- Open Terminal
2.- Go to your COMSOL Directory example: "cd /Applications/COMSOL44"
3.- Use the command : "open -n "COMSOL Multiphysics.app"
Done a new instance should be running. You can do the same for other versions of COMSOL.
Kind Regards,
Arpys
Hello, You can run a new instance by using the following command in the Terminal. open -na "COMSOL Multiphysics.app" Procedure to open from COMSOL installation directory: 1.- Open Terminal 2.- Go to your COMSOL Directory example: "cd /Applications/COMSOL44" 3.- Use the command : "open -n "COMSOL Multiphysics.app" Done a new instance should be running. You can do the same for other versions of COMSOL. -- Kind Regards, Arpys
Posted: 1 decade ago 2014/06/27 5:57 JST
Thanks for the solution, Arpys.
also worked well with Comsol 4.3b.
Thanks for the solution, Arpys. also worked well with Comsol 4.3b. [QUOTE] You can run a new instance by using the following command in the Terminal. open -na "COMSOL Multiphysics.app" [/QUOTE]
