heat trasnfer and fluid flow
Posted 2013/09/26 21:38 GMT-4 Version 4.3, Version 4.3a, Version 4.3b 4 Replies
i am modeling fluid flow (non-iso thermal pipe flow) for fluid flow in a pipe and heat transfer in solids for the ground surrounding the pipe.
i have defined a time dependent power (W/m) to the total length of my pipe. this is defined as function called F(t).
my problem is that the physic still requires a temperature defined at the inlet pipe (Tin)
how can i tell the model to apply temperature adjacent to the inlet pipe as the inlet temp. in other words for example telling the model to take the temperature at (0,0,0.11) which will be obtained from the heat trasnfer physic and apply on this boundary (inlet pipe).
thanks
ASAL
thanks
ASAL
4 Replies Last Post 2013/09/30 23:34 GMT-4
