2013/10/21 20:56 JST
I would like to know if it is possible to calculate a volume integral over an arbitrary (non-meshed) enclosed surface in the post-processing of a solution. An example might be integrating an electrical energy integral over a sphere and determining the change in that integral along a line.
thanks
Nicolas
"Volume integral over a surface"? You must draw a surface before calculating the solution; "change in that integral along a line"? You mean by varying the radius of the sphere? Then draw several (concentric?) spheres. Remember to include these extra spheres (or what ever they are) in the simulation domain.
Lasse
[QUOTE]
thanks
Nicolas
[/QUOTE]
Lasse
Jeff Hiller
COMSOL Employee
2013/10/21 22:07 JST
Hi Nicolas,
If you want to compute integrals on the SURFACE of that sphere, then you should define a dataset of the parametric surface type and compute your integral on that dataset.
If you want to compute integrals on the VOLUME inside the sphere, then simply use an expression that vanishes outside the sphere: something like your_integrand*(((x-x0)^2+(y-y0)^2+(z-z0)^2)<r0^2)
See the attached file that computes the average temperature on the surface of a sphere and the average temperature inside a sphere.
Hi Nicolas,
2013/10/21 22:31 JST
Thanks. I realise that my question was a bit confusing. I meant over the enclosed volume. I also specifically do not want to draw the domains and disrupt the mesh and I also want to be able to calculate this integral along a line through my simulation domain.
Nicolas
Nicolas
2013/10/21 22:33 JST
That looks ideal. I'll give it a shot and thanks for your time
Nicolas
Nicolas
2013/10/21 22:40 JST
Using this method, do you have to define every point for the sphere centres manually or could you calculate this average temperature along a line, say straight through the middle of your domain from the high temperature side to the low temperature side (obviously truncated by the closest position being the radius of the spherical volume). This would be to determine the average temperature experienced by a particle whose centre obviously cannot be closer than one radius away from the surface).
thanks again
Nic
thanks again
Nic
