buckling of a fixed mems membrane with initial stress applied
Posted 2013/10/28 6:44 GMT-4 MEMS & Nanotechnology, MEMS & Piezoelectric Devices, Structural Mechanics Version 4.1 0 Replies
example: ej.iop.org/images/0268-1242/28/1/012001/Full/sst446281f1_online.jpg
The membrane has 23 layers (Si3N4 and SiO2 alternately) of ca. 200nm thickness each. The legs are fixed at their ends (side surfaces). Each layer is prestressed (SiO2: -100MPa, Si3N4(bottom layers): 50MPa, Si3N4(upper layers): -160MPa). This Initial Stress makes the membrane buckle upwards. The experimental result is a deformation of 4.5 um (in the center of the memrane) . The simulation result is 1um.
I am using mems module, 3d geometry, application is solid mechanics, linear elastics material model, including geometric nonlinearity (large dimensions: on) and use nonlinear solver.
I would be very thankful for any hints.
Hello Szymon Sowizral
