Variable WAr in microwave plasma simualtion & other
Posted 2013/11/15 11:19 GMT-5 Plasma Physics, Studies & Solvers Version 4.3b 0 Replies
I'm trying to re-do all the steps of the following model : inplane_microwave_plasma.mph, available in the model library. I encountered two different problems that i don't understand.
1) When i use an union at the end of the design of the geometry (the 3 rectangles), i am not able to set properly the boundaries for the "Wall" and "Ground" : it says "not applicable" on the common border with the upper & lower rectangle ! Why is that ? In the model, it works... I got round this problem by using an assembly with contcat pairs instead, and everything work then. But it's not what the model was using... Any clue ?
2) More serious : when i try to compute the solution, i get an error message a few seconds after the beginning of the time dependant solver phase. It says :
Failed to evaluate variable jacobian
- Variable: WAr
- Geometry: 2
- Boundary: 8
- Feature: Time-Dependent Solver 1 (sol4/t1)
- Error: Failed to evaluate variable Jacobian.
So i displayed the equation and started looking for the WAr variable. Never able to find it. I just found this :
mwp.wAr=1-mwp.wArs-mwp_wAr_1p
mwp.wArs=exp(Re[WArs])
mwp.wAr_1p=exp(Re[WAr_1p])
But no hint of the localisation of those WArs nor WAr_1p and above all, WAr... Any idea on this ?
Thanks in advance,
Alexandre Bondoux
Hello Alexandre Bondoux
